Yes, seen that, but what I would like to know is, how do you go about removing the round plastic bit, the housing assy ?On the other side is a connector. Remove connector and then undo 2 torx screws and wiggle out sensor.
The 2 torx can be removed with small locking pliers to 1srt loosen and a flat screwdriver to unwind IF you havnt got the torx bits.
Normal self tappers can replace torx
Bazzle
Bazzle and jaymanek, Thanks for the advice. I may attempt this tomorrow, time permitting. The pics make it clear,
yes it just pulls off but be careful as the maf is very very delicate..
Fuzzer, That made me laugh, yes, I will soon have more spares here than MB direct.with your love for getting spare things , if there was ever a part to bring your car to its knees its the maf.
If its going ok leave it. If your going to mess about with it and your distance from a shop thats likely to have one id be cautious...!
How do you remove the retaining ring ?The air mass does not just pull off. There is a retaining plastic riing around the top of it that needs to be released. This ring is brittle and breaks easily so be careful!!!
