Hi
Please give me your opinion on whether the valve guides can be changed on a 1987 M103 while the head stays on. I have read some articles which seem to suggest that with a special valve spring compressor, you can remove the collets, then pull off the valve guides and pop on new ones - i guess while the valve it just hanging there (or, i suppose you must hold it to stop it falling down into the chamber. Is this process only if you have a pressurized chamber with an air pump?
All your advice greatly appreciated. For those who regularly help me with my project, i have just discovered that at least 3 of my pots have oil leaking into them (when the engine reaches about 81 degrees), which fouls up the plug.
(I also took the car for a scan and it found that 2 injectors were partially blocked so i changed them)
best
m in Beirut
best
m in Beirut
