Well the 7 months in a body shop did my valve stem seals no good.. I found I was getting a lot of smoke when hot at idle or pull off.
With some special tools, this job can be done without taking the heads off.
This is only a job for a professional IMO and I called in some help for this one.
General outline:
First you need to dismantle the top end and remove the cams. Lock the engine to stop it turning later..
Then you need to remove the plugs and use a compressed air line with a special adaptor to fit in the plug holes. This keeps the valves tightly closed. Engine may turn here if not locked.
Then you need compress the springs using a special valve spring compressor and then they can be removed... Dont lose the little half moon retainers otherwise you will be in trouble!
The old valve stem seals can now be seen and can be removed.
The new ones have to be treated very carefully, a slight nick in the rubber will mean all this hard work to be for nothing. You have special tube come with the kit from MB which you slide the seals over. We also lubricated them with some oil..
They can be pushed home with the correct sized socket and a light tap with a hammer.
Once all 16 are done, re assemble..
One of the old ones, had gone very hard compared to the andrex puppy soft new ones.
Didnt get a pic of the new ones... a bit tricky to be holding a camera...
A job I wont want to do again.. im sure it would have been quicker just to transplant engines from one of the donor cars I have!
General outline:
