Hi Guys! Here is a reply from Sweden. I have read through your tread here and find several errors in statements and belief. Almost all cars can run on WVO/SVO.
A few limits, that is cars with ACDelco, CAV and Delphi pumps. In USA they have a pump called Stanadyne. That one is not either suitable.
As long as you do everything the correct way, there is NO REASON what so ever not to drive in waste veggie oil. Remember you use a products which is a waste, and in most cases thrown down the pipes or out in the nature, if not burned in oil burners.
The veggie oil lubricate the same as Diesel. In fact, if you heat diesel today, it lubricate much less now because of reduced sulfur in diesel. Several new trucks and bus brands ADD a liquid to the injection pump and nozzles to lubricate the mechanical parts.
You do NOT loose effect by using veggie oil as said at the forum.
The smell from your exhaust is like when you make pancakes, and the exhaust is much more CLEAN than from Diesel! We have had controls here by authorities in Sweden, where the controller had no idea that the engine was running on wvo. They believed their equipment was incorrect, because it should not be possible to have such clean exhaust from a diesel engine!
If you do not want to convert your car, you may blend your WVO with either diesel or petrol.
You may blend diesel from 5% up to 90% if you want and depends of temperature.
But remember that when temperatures goes low, the diesel and wvo may split up again, and the wvo will get thicker than dieel, and sink down at the ottom of the tank. This may cause your pipes and filters clog. But as long as you keep them well mixed, there is no problem. Just don't fill up your tank, but keep a minimum in your tank, and keep the rest on a 20 l container.
For blend with petrol, you may mix up to 10%
If you choose to convert your car, you need an extra tank in the trunk, a small membrane pump, a heated filter and valves to switch over between diesel and wvo.
The you can drive your engine all year around. When you have very cold weather, like minus degrees C. You start your engine on diesel, switch over to wvo, and vise versa when stop.
If you visit,
Selko Motor you will find a lot of information and pictures.
The text is in Norwegian, but Google will easily translate what u like to read today.
Myself has 10 years of experience with wvo, and ha saved thousands of pound in fuel through the years. And no harm to my motor.
Any questions is welcome.
