What happens when the rubber spacer behind the crank pulley (I think?) perishes, shrinks, and allows the hardened steel pulley wheel to wobble on its axis?
(Photo courtesy Olly @PCS..)
It's leaking oil and requires an engine-out repair, the cost of which approaches 50% the value of the car (on top of everything else it went to PCS for).
Painful business, owning a car that is cheapish to acquire and then expensive to run; I could break it and buy a new one with half the mileage and not come out much worse off (if at all) and yet.. and yet...
