Main data
Parameter Value
Ident. number (FIN) WDF63981523231695
Baumuster 639815
Sales name CDI22AMB/E4X2 3430
Permanent link http://carinfo.kiev.ua/cars/vin/mercedes/vin_check?su=3yh9z6o
Order number 5 6 539 49176
Delivery date 2006-03-23
PAINT1 9744
Interior color 1332
Engine 646982 50 223385
Variant A 646 010 86 00
Number for spare parts 64698250
Text DER BESTELLTE MOTOR MIT CODE KL5 (KRAFTSTOFFILTER MIT WASSERABSCHEIDER) IST NICHT LIEFERBAR. BITTE MOTOR A 646 010 77 00 VERWENDEN UND KRAFTSTOFFILTER, MOTORLEITUNGSSATZ UND KRAFTSTOFFSCHLAUCH VOM ALTMOTOR UEBERNEHMEN, ODER LAUT EPC NEU BESTELLEN THE ORDERED ENGINE WITH CODE KL5 (FUEL FILTER WITH WATER SEPARATOR) IS NOT AVAILABLE. PLEASE USE ENGINE A 646 010 77 00 AND TAKE THE FUEL FILTER, THE ENGINE CABLE HARNESS AND THE FUEL HOSE FROM THE OLD ENGINE OR ALTERNATIVELY ORDER NEW ACCORDING TO EPC
Gearbox 722682 06 457580
Body 3
Class 3
Infotable on engine A01000646 86
General data for model code 639815
SA codes
Code Value
1332 No code designation available
181 No code designation available
213K No code designation available
423 No code designation available
617K No code designation available
9744 PAINT COLOR, BRIL.SILVER METALLIC MB 9744
AC7 AXLE RATIO I = 3.273
BB3 ELECTRONIC STABILITY PROGRAM (ESP)
C42 STABILIZER,REAR AXLE UNDER THE FRAME
CF1 SPRINGS, SHORT
CL0 AIR SUSPENSION LOWER/RAISABLE
CL2 LEATHER STEERING WHEEL AND LEATHER GEAR SHIFT KNOB
CL4 MULTIFUNCTION STEERING WHEEL WITH TRIP COMPUTER
CM2 BUMPER AND DETACHABLE PARTS PAINTED VEHICLE COLOR
D12 ROOF RAILING/TRUNK LID RACK
EE8 12V BATTERY 100 AH
EL9 2-WAY SPEAKER AT FRONT AND REAR
ES1 12 V SOCKET PASSENGER COMPARTMENT
EU4 AUDIO 10 RADIO WITH SINGLE CD PLAYER
F61 INSIDE REARVIEW MIRROR
F64 ELECTRICALLY FOLDING OUTSIDE MIRROR
F66 LOCKABLE GLOVE COMPARTMENT
F69 ELECT.ADJ.& HEAT.OUTSIDE MIRR. W/INTEG. TURN SIGN.
FF1 CENTER CONSOLE WITH STOWAGE COMPARTMENT
FH1 TRIM PIECES BURRED WALNUT VENEER DESIGN BROWN
FQ9 CD BOX
FS5 ILLUMINATED MIRRORS FOR SUN VISORS
FZ8 CONVENIENCE OPENING/CLOSING W. INFRARED REM.CONTRL
G40 AUTOMATIC TRANSMISSION
H00 HOT/COLD AIR DUCT TO PASSENGER COMP.
H15 SEAT HEATER FOR FRONT PASSENGER
H16 SEAT HEATER FOR DRIVER
H20 HEAT-ABSORBING GLASS ALL ROUND
HH4 THERMOTRONIC AUTOMATIC AIR CONDITIONING
HZ0 ELECTRIC HEATER BOOSTER
HZ7 SEMI-AUTOM. REGULATED A/C, TEMPMATIC IN REAR
IL2 EXPORT CODE
J64 MAINTENANCE INDICATOR FOR DRY AIR FILTER
J65 OUTSIDE TEMPERATURE INDICATOR
JA1 INDICATOR LAMP FOR WIPER FLUID LEVEL
JC2 SOFTTOUCH COCKPIT
JK3 INSTRUMENT CLUSTER WITH PIXEL MATRIX DISPLAY
KL5 FUEL FILTER WITH WATER SEPARATOR
L10 ILLUMINATION FOR LEFT-HAND TRAFFIC
LB9 EXIT LAMPS
LD0 OVERHEAD CONTROL PANEL WITH 2 READING SPOTLIGHTS
LD5 ADDITIONAL INTERIOR LAMP IN PASSENGER COMPARTMENT
M40 ALTERNATOR 14 V / 200 A
MC3 ENGINE OM646 DE22LA 110KW (150HP) 3800RPM
MF8 LOW-EMISSION VEHICLE EURO 3 GR. II/III
MS1 TEMPOMAT (CRUISE CONTROL)
RF9 TIRE MANUFACTURER GOODYEAR (90)
RG7 TYRES 225/55 R17
RL8 LIGHT-ALLOY WHEELS 7JX 17
RM4 COMFORT TYRES
RR6 SPARE WHEEL WITH JACK
SA6 CO-DRIVER'S AIR BAG
SB1 DRIVER SEAT, COMFORT
SB2 PASSENGER SEAT, COMFORT
SE4 LUMBAR SUPPORT FOR PASS. SEAT
SE5 LUMBAR SUPPORT FOR DRIVER SEAT
SH7 THORAX SIDEBAG F.DRIVER + FRONT PASS.(IN BACKREST)
SZ4 RUFFLED POCKET(S), FRONT INDIV. SEAT BACKREST(S)
T19 SLIDING DOOR LEFT
T70 CHILD SAFETY LOCK ON DOORS IN PASS. COMP.
UR1 SEAT RAIL SYSTEM WITH QUICK COUPLING
US6 SINGLE SEAT 1. ROW LEFT
US7 SINGLE SEAT 1. ROW RIGHT
US8 SINGLE SEAT 2. ROW LEFT
US9 SINGLE SEAT 2. ROW RIGHT
V33 CARPET IN REAR
V36 HEADLINER
V44 CARPET IN FRONT VEHICLE INTERIOR
V77 LUGGAGE COVER AND NET FOR PASSENGER PROTECTION
VH1 GRAB HANDLES IN REAR
VP3 EQUIPMENT LINE, AMBIENTE
VT7 CATANIA ORION GRAY LEATHER
W16 LEFT FRONT WINDOW, FIXED IN SIDE WALL/SLIDING DOOR
W17 RIGHT FRONT WINDOW,FIXED IN SIDE WALL/SLIDING DOOR
W32 ELETRIC VENT WINDOW PASSENGER COMPARTMENT
W65 TAILGATE
W70 COLOR GLAZING IN REAR, BLACK GLASS
W78 LIFTGATE/REAR-END DOOR WINDOW W/ WIPER+WASHER SYS.
X42 PLATES / PRINTED MATERIALS ENGLISH
XA2 WEIGHT VERSION 2940 KG
YE5 ASH TRAY AND DRINKS HOLDER IN PASS. COMP.
Z42 APPROVAL AS PASSENGER CAR
SA numbers
Group Codes
01 01 522600/02/ 01 522601/06/ 01 522602/03/ 01 522603/04/ 01 522604/03/ 01 522605/03/ 01 522611/03/ 01 522616/02/ 01 522634/03/ 01 522636/03/ 01 522638/01/ 01 522639/01/ 01 522642/03/ 01 522644/01/ 01 522645/03/ 01 522674/01/
03 03 522606/03/ 03 522607/03/ 03 522608/06/ 03 522609/10/ 03 522634/03/ 03 522640/05/ 03 522641/01/ 03 522650/03/
05 05 522605/03/ 05 522610/03/ 05 522619/02/ 05 522624/02/ 05 522629/02/ 05 522639/01/ 05 522642/03/
07 07 522612/03/ 07 522613/07/ 07 522614/03/ 07 522617/03/ 07 522647/03/ 07 522651/03/ 07 522651/08/
09 09 522615/03/ 09 522615/21/ 09 522617/03/
13 13 522618/03/
14 14 522617/03/ 14 522620/03/ 14 522673/01/
15 15 522603/04/ 15 522605/03/ 15 522622/06/ 15 522630/06/ 15 522630/12/ 15 522649/18/
18 18 522623/03/ 18 522625/03/ 18 522626/01/ 18 522627/02/ 18 522629/02/ 18 522639/01/
20 20 522628/02/ 20 522632/02/ 20 522661/03/ 20 522672/03/
22 22 522614/03/ 22 522643/03/ 22 522667/03/
System information
Group Codes
Data language en
DB storage version 1.0
Data display version 2.1
Manufacturer's data version DW 01/2015 Delta 2 from 2015-01-22
Marko, your first post said you don't know, which was frankly a bizarre thing to post, and your second is an assumption. Neither are very helpful.
Very comprehensive datacard results you got there dahamsta. Do you mind posting a link to the site that supplied the results of your request in that format please.?So there are, thanks. Here's the datacard info, I don't see any mention of a DPF, but might it be listed as something more obscure?
Code:Main data Parameter Value Ident. number (FIN) WDF63981523231695 Baumuster 639815 Sales name CDI22AMB/E4X2 3430 Permanent link http://carinfo.kiev.ua/cars/vin/mercedes/vin_check?su=3yh9z6o Order number 5 6 539 49176 Delivery date 2006-03-23 PAINT1 9744 Interior color 1332 Engine 646982 50 223385 Variant A 646 010 86 00 Number for spare parts 64698250 Text DER BESTELLTE MOTOR MIT CODE KL5 (KRAFTSTOFFILTER MIT WASSERABSCHEIDER) IST NICHT LIEFERBAR. BITTE MOTOR A 646 010 77 00 VERWENDEN UND KRAFTSTOFFILTER, MOTORLEITUNGSSATZ UND KRAFTSTOFFSCHLAUCH VOM ALTMOTOR UEBERNEHMEN, ODER LAUT EPC NEU BESTELLEN THE ORDERED ENGINE WITH CODE KL5 (FUEL FILTER WITH WATER SEPARATOR) IS NOT AVAILABLE. PLEASE USE ENGINE A 646 010 77 00 AND TAKE THE FUEL FILTER, THE ENGINE CABLE HARNESS AND THE FUEL HOSE FROM THE OLD ENGINE OR ALTERNATIVELY ORDER NEW ACCORDING TO EPC Gearbox 722682 06 457580 Body 3 Class 3 Infotable on engine A01000646 86 General data for model code 639815 SA codes Code Value 1332 No code designation available 181 No code designation available 213K No code designation available 423 No code designation available 617K No code designation available 9744 PAINT COLOR, BRIL.SILVER METALLIC MB 9744 AC7 AXLE RATIO I = 3.273 BB3 ELECTRONIC STABILITY PROGRAM (ESP) C42 STABILIZER,REAR AXLE UNDER THE FRAME CF1 SPRINGS, SHORT CL0 AIR SUSPENSION LOWER/RAISABLE CL2 LEATHER STEERING WHEEL AND LEATHER GEAR SHIFT KNOB CL4 MULTIFUNCTION STEERING WHEEL WITH TRIP COMPUTER CM2 BUMPER AND DETACHABLE PARTS PAINTED VEHICLE COLOR D12 ROOF RAILING/TRUNK LID RACK EE8 12V BATTERY 100 AH EL9 2-WAY SPEAKER AT FRONT AND REAR ES1 12 V SOCKET PASSENGER COMPARTMENT EU4 AUDIO 10 RADIO WITH SINGLE CD PLAYER F61 INSIDE REARVIEW MIRROR F64 ELECTRICALLY FOLDING OUTSIDE MIRROR F66 LOCKABLE GLOVE COMPARTMENT F69 ELECT.ADJ.& HEAT.OUTSIDE MIRR. W/INTEG. TURN SIGN. FF1 CENTER CONSOLE WITH STOWAGE COMPARTMENT FH1 TRIM PIECES BURRED WALNUT VENEER DESIGN BROWN FQ9 CD BOX FS5 ILLUMINATED MIRRORS FOR SUN VISORS FZ8 CONVENIENCE OPENING/CLOSING W. INFRARED REM.CONTRL G40 AUTOMATIC TRANSMISSION H00 HOT/COLD AIR DUCT TO PASSENGER COMP. H15 SEAT HEATER FOR FRONT PASSENGER H16 SEAT HEATER FOR DRIVER H20 HEAT-ABSORBING GLASS ALL ROUND HH4 THERMOTRONIC AUTOMATIC AIR CONDITIONING HZ0 ELECTRIC HEATER BOOSTER HZ7 SEMI-AUTOM. REGULATED A/C, TEMPMATIC IN REAR IL2 EXPORT CODE J64 MAINTENANCE INDICATOR FOR DRY AIR FILTER J65 OUTSIDE TEMPERATURE INDICATOR JA1 INDICATOR LAMP FOR WIPER FLUID LEVEL JC2 SOFTTOUCH COCKPIT JK3 INSTRUMENT CLUSTER WITH PIXEL MATRIX DISPLAY KL5 FUEL FILTER WITH WATER SEPARATOR L10 ILLUMINATION FOR LEFT-HAND TRAFFIC LB9 EXIT LAMPS LD0 OVERHEAD CONTROL PANEL WITH 2 READING SPOTLIGHTS LD5 ADDITIONAL INTERIOR LAMP IN PASSENGER COMPARTMENT M40 ALTERNATOR 14 V / 200 A MC3 ENGINE OM646 DE22LA 110KW (150HP) 3800RPM MF8 LOW-EMISSION VEHICLE EURO 3 GR. II/III MS1 TEMPOMAT (CRUISE CONTROL) RF9 TIRE MANUFACTURER GOODYEAR (90) RG7 TYRES 225/55 R17 RL8 LIGHT-ALLOY WHEELS 7JX 17 RM4 COMFORT TYRES RR6 SPARE WHEEL WITH JACK SA6 CO-DRIVER'S AIR BAG SB1 DRIVER SEAT, COMFORT SB2 PASSENGER SEAT, COMFORT SE4 LUMBAR SUPPORT FOR PASS. SEAT SE5 LUMBAR SUPPORT FOR DRIVER SEAT SH7 THORAX SIDEBAG F.DRIVER + FRONT PASS.(IN BACKREST) SZ4 RUFFLED POCKET(S), FRONT INDIV. SEAT BACKREST(S) T19 SLIDING DOOR LEFT T70 CHILD SAFETY LOCK ON DOORS IN PASS. COMP. UR1 SEAT RAIL SYSTEM WITH QUICK COUPLING US6 SINGLE SEAT 1. ROW LEFT US7 SINGLE SEAT 1. ROW RIGHT US8 SINGLE SEAT 2. ROW LEFT US9 SINGLE SEAT 2. ROW RIGHT V33 CARPET IN REAR V36 HEADLINER V44 CARPET IN FRONT VEHICLE INTERIOR V77 LUGGAGE COVER AND NET FOR PASSENGER PROTECTION VH1 GRAB HANDLES IN REAR VP3 EQUIPMENT LINE, AMBIENTE VT7 CATANIA ORION GRAY LEATHER W16 LEFT FRONT WINDOW, FIXED IN SIDE WALL/SLIDING DOOR W17 RIGHT FRONT WINDOW,FIXED IN SIDE WALL/SLIDING DOOR W32 ELETRIC VENT WINDOW PASSENGER COMPARTMENT W65 TAILGATE W70 COLOR GLAZING IN REAR, BLACK GLASS W78 LIFTGATE/REAR-END DOOR WINDOW W/ WIPER+WASHER SYS. X42 PLATES / PRINTED MATERIALS ENGLISH XA2 WEIGHT VERSION 2940 KG YE5 ASH TRAY AND DRINKS HOLDER IN PASS. COMP. Z42 APPROVAL AS PASSENGER CAR SA numbers Group Codes 01 01 522600/02/ 01 522601/06/ 01 522602/03/ 01 522603/04/ 01 522604/03/ 01 522605/03/ 01 522611/03/ 01 522616/02/ 01 522634/03/ 01 522636/03/ 01 522638/01/ 01 522639/01/ 01 522642/03/ 01 522644/01/ 01 522645/03/ 01 522674/01/ 03 03 522606/03/ 03 522607/03/ 03 522608/06/ 03 522609/10/ 03 522634/03/ 03 522640/05/ 03 522641/01/ 03 522650/03/ 05 05 522605/03/ 05 522610/03/ 05 522619/02/ 05 522624/02/ 05 522629/02/ 05 522639/01/ 05 522642/03/ 07 07 522612/03/ 07 522613/07/ 07 522614/03/ 07 522617/03/ 07 522647/03/ 07 522651/03/ 07 522651/08/ 09 09 522615/03/ 09 522615/21/ 09 522617/03/ 13 13 522618/03/ 14 14 522617/03/ 14 522620/03/ 14 522673/01/ 15 15 522603/04/ 15 522605/03/ 15 522622/06/ 15 522630/06/ 15 522630/12/ 15 522649/18/ 18 18 522623/03/ 18 522625/03/ 18 522626/01/ 18 522627/02/ 18 522629/02/ 18 522639/01/ 20 20 522628/02/ 20 522632/02/ 20 522661/03/ 20 522672/03/ 22 22 522614/03/ 22 522643/03/ 22 522667/03/ System information Group Codes Data language en DB storage version 1.0 Data display version 2.1 Manufacturer's data version DW 01/2015 Delta 2 from 2015-01-22
