trevor1965
Driving the other night ,when there was a rattle from under the bonnet . Stopped too look ,found that radiator fan was sitting inside the radiator fan cowling ,having detached or sheared itself off of ,i'm assuming the water pump as I could see no electric motor or associated bracketry. My question is simply ,is the fan attached to the water pump by a viscous coupling or does it bolt directly ,as there is a steel boss with hex flats protruding from the back of the fan . Any advice/ knowledge ,especially on reattaching appreciated ,as access does look quite tight,thanks
