Viano instrument upgrade
Discussion in 'Electronics' started by Marku, Nov 25, 2017.
  1. Marku
    Marku Hardcore MB Enthusiast
    748
    Dec 18, 2012
    Car:
    Viano Ambiente 2.2CDI W639, S-Class 450SE W116
    Had the opportunity to upgrade from the old fan instrument on a 2006 Viano to the Hi-line two dials. Everybody said its easy simply swap them except it isn't. The plug on the Viano will not fit the socket on the Hi-line. Both have 18 pins and superficially they would appear to fit but offer them up and the keys on the plug are wider apart than those on the socket. Any easy solution or is it a non-starter?
  2. wu56Shoozz
    wu56Shoozz Hardcore MB Enthusiast
    1,983
    Jun 17, 2016
    You'll need a passport to get over the Wall..
    Car:
    MB Vito 111CDi / W203 C Class Saloon 320CDi Avantgarde
    I'm told its an non starter the two dashes won't match and will need wiring AND coding to the car if successful.. sorry mate :-(
  3. zenman63
    zenman63 Hardcore MB Enthusiast
    2,227
    Feb 8, 2010
    Warwickshire
    Car:
    172 Slk 250 & Porsche 911 991.2 S Cayman 3.6S
    Hi, Its all been done and covered here on the forum, the pictures will be missing sadly but yes it can be done easy enough, you need the change the plug housing and move all the pins in the plug to new positions.
    Cluster will need setting to zero or a new one fitted.
    See if the search works or look back on my old posts.
  4. OP
    OP
    Marku
    748
    Dec 18, 2012
    Car:
    Looked back as you suggest and yes it can be done but I have to admit that I think it beyond me. I can't figure out which pin correlates to which so I guess I will have to pass on it. Pity nice replacement looks like it will end up on the shelf.
  5. zenman63
    2,227
    Feb 8, 2010
    Warwickshire
    Car:
    I have the details on the pins, I will dig them out.
    clk320x and Marku like this.
  6. OP
    OP
    Marku
    748
    Dec 18, 2012
    Car:
    That would be great if you would. I really don't like giving up on things and have been thinking about it ever since my posting and will have another go. Can I fit the new plug and if so where might I get one?
  7. clk320x
    clk320x MB Club Veteran
    9,863
    Sep 27, 2016
    Midlands
    Car:
    W211 E320 CDI, W212 E250 CDI, W203 C32 AMG
    This is what makes this forum great :thumb::thumb::thumb:
  8. zenman63
    2,227
    Feb 8, 2010
    Warwickshire
    Car:
    plug is in two parts, the white outer case is the housing and the black inner is the pin housing, that stays the same.
    All from MB parts
  9. zenman63
    2,227
    Feb 8, 2010
    Warwickshire
    Car:
    PIN COLOUR GAUGE DESCRIPTION
    01 BROWN/YELLOW 0.75 W1/6 Ground
    02
    03
    04 RED/GREY 0.75 K40/9 PIN2 (+12v)
    05
    06 BLACK/PINK 0.5 K40/9 PIN4
    07 BRWON 0.5 U905/6 PIN2
    08 WHITE 0.5 U905/6 PIN1
    09 GREY/GREEN 0.5 U909 Radio / Command
    10
    11
    12 GREEN 0.5 X30/27 PIN2
    13 GREEN/WHITE 0.5 X30/27 PIN1
    14 BLACK/BLUE 0.5 K40/9 PIN8
    15 BLACK/YELLOW 0.5 K40/9 PIN1
    16
    17 BROWN 0.5 X30/24 PIN2
    18 BROWN/RED 0.5 X30/24 PIN1
    19
    20
  10. OP
    OP
    Marku
    748
    Dec 18, 2012
    Car:
    As has just been said that's what makes the forum great. Thank you very much for your help. Will post my progress.
  11. OP
    OP
    Marku
    748
    Dec 18, 2012
    Car:
    Have opted for replacing the plug rather than attempting any reworking of the existing one. Got one ordered and hope to get round to it at the weekend.
  12. OP
    OP
    Marku
    748
    Dec 18, 2012
    Car:
    Keep getting all worked up to do this but they keep sending me the wrong plug. Have another go tomorrow to get the right one. Not me with the wrong part number, I don't have it, but have made real efforts to explain what I want obviously without success.
  13. OP
    OP
    Marku
    748
    Dec 18, 2012
    Car:
    Solved the problem of the plug although they must make one that fits I can't seem to get hold of one. You just modify they old one. Take off the end keys on the right and it fits perfectly. Next step to wire it up and see if it works.
  14. OP
    OP
    Marku
    748
    Dec 18, 2012
    Car:
    Well I guess that this is the end of the project. Got it all stripped out ready to install and I am missing connections for pins 11,12 and 13 which on the new display is apparently for radio, comand and phone etc. As it is fitted with those items and obviously wired into the old display I now have no way of knowing which pin is which on the old display and would connect to the new. Pity I was looking forward to the new look.
  15. zenman63
    2,227
    Feb 8, 2010
    Warwickshire
    Car:
    No just fit it, I did post a while back with the plug part number, its the same as a w203 if that helps.
    Wires missing is fine, its mostly on Can anyway so no problem with comand etc
    Marku likes this.
  16. OP
    OP
    Marku
    748
    Dec 18, 2012
    Car:
    Thanks for that I need all the support I can get as vehicle electronics are a mystery to me. I can just about manage the 450SE I have but even that has electronic fuel injection that I have yet to come to terms with. Mercedes went with mechanical two years later. I got it, its 1974, not just out of interest but I thought it would more simple. Any way I plan to have another go at the Viano this week. We are real enthusiasts for it and plan to keep it now as it is the most useful vehicle we have had.
  17. OP
    OP
    Marku
    748
    Dec 18, 2012
    Car:
    Well had a go at installing the new display much trouble having to replace some of the pin connectors plugged it all in and nothing. Thought it would have at least showed some life and lighted up. Looked really good in place big improvement must be doing something wrong so back to the drawing board.
Share This Page
