Viano or Vito seat tracks
Romt5962
Lyndhurst
C class
Hi I'm new to this forum and have some questions about seats and rails etc.
I'm thinking of buying an xlwb Viano or Vito to use as part car ,part van and also as a windsurfing van to carry my kit. It is tricky at moment as not really able to visit dealers to take measurements. So hopefully someone can help.
I really only want 4 seats driver, front passenger and 2 single seats behind. Q can anyone tell me what the maximum gap could be between the seats? Are there single seats without armrests or can the arm rests be removed? Can the seats be moved to side of van? Ideally I want to slide a long board( windsurfer) up the centre of the van. The board is 3.6m long and I think it would go in length ways (?) and I need about 250mm of width between the seats. From looking at other threads it seems the seat tracks are pretty much fixed but wondering what can be done.
Thanks in advance
m80
Derbyshire, High Peak
Viano, 651 2014. W211 646 (for a short while)
I can measure later.
Arm rests can be removed, unclip cover, one hax bolt out, pull. It will leave a hole in the seat.
If you go for long floor rails they are designed for 2 rows (additional to driver and front passenger).
Seats can be configured to face either way and on either side. so 2 seats to the n/s , or o/s,facing forward or facing each other might suit you.
On the exlwb a 2.4m sheet plus a bit can fit. You could slide a surf board between the front seats and get the extra length needed, I think.
There is a lot of info here and t'other place. The info would be invaluable when you start to look.
OP
OP
R
Romt5962
Lyndhurst
C class
Thanks very helpful especially about putting them on side. I guess the gap down centre is quite wide then. Appreciate your help.
Rpp999
Bexleyheath/ St Benoit du Sault.
C220 est amg 4matic. LR Discovery. BMW1200gs
Hi, I have had a few Vitos, and the rear seat fixings and seating combinations are probably not going to suit your requirements. Where as the Viano has the sliding rail option and is a lot more flexible in the seating configuration.
BTB 500
MB Club Veteran
Berkshire
R129 SL500, W639 Vito 120, S205 C300
If you can get a Vito Dualiner with 'comfort' rear seating you get two units (a double plus a single), rather than a 3-seat bench. These are separately removeable - we run ours with just the double there, which leaves a big gap on one side which might well work for you. The rear seats have individual backrests which recline or fold forward (flat), and the base units can then be flipped forward. It's pretty versatile but as mentioned you can't move the rear seats fore/aft like you can (I think) in a Viano. The outer two seats have armrests, but these simply unbolt if you don't want them. Picture of ours (we have caging in the back for dogs):
Rpp999
That picture shows exactly why I don’t think the Vito is going to be suitable for the OP.
To be able to carry a 3.6m board he will have to carry it right through the middle and into the space between the driver and passenger seats. The Vito rear seats will have to be totally removed
BTB 500
MB Club Veteran
Berkshire
Good point but actually I don't think you'd get a 3.6m board in at all. The Extra Long is officially 2897 mm from the tailgate to the back of the front seats ... I just looked at mine and I don't think there's another 70 cm between there and the centre console. I suspect roof bars would be the only option.
OP
OP
R
Romt5962
Lyndhurst
C class
Thanks for all the comments.
Agree I think bench seats don't look an option. Would really appreciate the dimension right up to the underside of the dash. It does look like it may not be possible.Hmmm maybe back to drawing board
m80
Taken from a 639 Viano Ex long.
Expect the same for a Vito, although a little extra length might be gained by removing or working the tailgate inner trim.
Between seats with arm rests removed 203mm
There would be significantly more space allowed if both seat were to one side.
From inside of tailgate to back of gear change surround 3.5m
OP
OP
R
Romt5962
Lyndhurst
C class
Thanks I think I will have to go back to having long board on roof. Shame as at 15 kgs above head height it can be a pain in a strong wind!!! The rest of the kit will fit in a lwb so probably more choice of vans. Much appreciate your help.
BTB 500
MB Club Veteran
Berkshire
To be accurate, the Compact and Long both have the same wheelbase ... it's only the Extra Long that is LWB. The sizes are now called L1 / L2 / L3 on the current version, probably to reduce confusion!
