rburnham11
- Sep 6, 2016
- Mercedes vito
Hi all
I have a 04 plate viano, what mpg would you expect? Currently I do the same 50mile journey to work then 50miles back every day, you'd expect the mpg displayed on the dash to be the same or similar for each journey, one trip would be about 31mpg then the next exact same journey would be like 23mpg. What could cause such a difference.
Also when accelerating from stand still a fair bit of black smoke appears out the back, leads me to believe something is not quite right. So far all I've done is change air filter as I had a new one knocking around.
I have another Vito pretty much identical and that regularly gets 38 to 40ish mpg granted that's a manual and only has 5 seats where viano has 8 seat and is auto.
Only problems that may or may not be connected that I know of is- the lights come on with the ignition regardless of light switch position, the AC makes a noise at idle and doesn't blow cold until moving faster. The mpg is pretty much same no matter if AC is on or off.
Any help or ideas would be most appreciated as I have a long long drive next month that I really would like to have viano sorted before heading off.
Cheers
Rich
Cheers
Rich
