- Feb 8, 2010
- Location
- Warwickshire
- 2016 L450 Range Rover 4.4 AB, 2015 GTs 2017 Range rover evoque
This is the amp Part number A639 820 22 89 made for the NTG 2.5.
zenman63 said:This is the amp Part number A639 820 22 89 made for the NTG 2.5.
There you go, just glad you have made a start.
The reverse camera lead I got from ebay, A guy made me a 6m leaded with a green 90deg fakra to rca for less than £10 delivered.
Make sure the camera is NTSC or it will be black and white.
miro said:The camera standard is selectable. In any event, one should probably use a Mercedes modulator to isolate the camera from the head unit. Then it solves the issue of it being NTSC or PAL.
