Vibration at motorway speeds - unknown cause
benmays99
UK
1990 W126 300SE
Hi guys wonder if I get your suggestions on my latest W126 job
I have a vibration felt through the floor and the steering wheel at motorway speeds of 60-80mph. I've had the wheels welded and balanced as they were slightly bent which I thought would fix the issue but the vibration still remains but is lessened.
What could the culprit be now? I'm thinking my next step should be to get a 4 wheel alignment? If not maybe it could be to do with the prop shaft balancing or somewhere else in the driveline?
Let me know if anyone has any thoughts!
Ben
whitenemesis
MB Club Veteran
Lexus RC300h F-Sport 2019
I'd say if this has lessened the vibration maybe it needs to be readdressed as it may still be the cause of an imbalance in one or more of the wheels
DucatiEVO
Oxford
2012 Mercedes C250 AMG Sport Plus Estate
Ditto, 60-80 sounds like prime wheel balancing issues, front and rear if you're feeling it through the steering wheel, and body.
Boyband
West Midlands
Mercedes C207 E400
Hi , I have a C207 and suffered from a slight vibration through the steering wheel at 70mph.Two points I would suggest that you look at the condition of the tyres ( I don't mean tread depth ) .
The front tyres were breaking up although they had only covered covered 8000.New tyres and the problem went away.
Many years ago I had a Ford Escort Mexico with Dunlop SP 68 on the car and had a similar problem.
Dunlop agreed to change the tyres but asked if I would tyre something first , agreed , the rep asked me to rotate the tyres through 180 deg on the wheel and rebalance the tyres.
Vibration went away
jimjamiejames
S211 e350, daimler sovereign custom project
If you believe the issue is wheel balancing related get on a road force machine. It cured my problems, only issue is finding one and also a skilled operator
SL03WLY
South East, UK
W211 03'
Ben
I had similar and it was shaking my passenger seat. Turned out to be a buckled alloy wheel. I had the road force balancing done (which is where they found it buckled) and the balancing reduced it a lot until I got the buckled fixed.
