keastygtir
- Jun 26, 2013
- Pulsar GTiR
Hi Guys
I could do with some advice regarding my Vito 108 (03). Recently the van has been cutting out. Sometimes it has happened just after starting up, sometimes at idle but more concerning is that it has cut out a couple of times today just driving along.
When it cuts out often the glow plug light will come on just before, the van restarts fine afterwards.
When buying the van I did a service with a new fuel filter and also had the injectors visually inspected for signs of black death which were all clear.
I have noticed that when driving with the window slightly open it smells a bit fuelly, also not sure if it could be related but on WOT you can hear an induction whooshy noise.
I would appreciate your thoughts as the engine cutting out while running is quite dangerous.
Kevin
Kevin
