Hi Everyone
Looking for a bit of advice, I have a 'x' reg vito 108cdi. I have not owned that long so not sure if the speed and power I am receving is normal. I feel that I am not getting the power i thought I would from the van in running up through the gears you dont seem to get that ummp like you do from transits and vw etc. Revs are fine as in goes up to around 3500-4000 in all gears but top speed on flat is around 75-80 max takes a while to get there and if you hit a hill you can drop to 40 - 50 (and i dont mean everest). I thought being a 2.2 turbo I would have a bit more power. It did go into limp mode once and I found a vac pipe to a sensor on the bulkhead behind the inlet manifold loss, pushed back in and came out of limp mode( paid a garage £75 not to find that). Any help or info would be great as do use van daily now.
