Vito 110cdi tapping sound
swirl flaps ??
If fitted.
@StMarks
I would put up with the noise as its a van.
But if you're a perfectionist then get some quotes and make your decision :)
Most vans I get in need to be on the road earning money so they just get driven with the noise till something else goes wrong.
Customer deems repairs too costly and gets a new one after 2-3 years.
Thanks for your wisdom.
I guess that (although it goes against my nature) I may well re-fit & put up.
I do not expect to be using it very much.
I would like to reduce the possibility of ingesting a swirl flap (if that was the cause), so I had better look into that.
As an alternative, do you know if a 108cdi engine would be a suitable donor for the block & piston for my 110cdi.??
Or are there major component differences that anyone knows about please.?
I would buy a complete 110 engine as you know all the ancillaries will fit from your old engine corerctly, and most s/h places will give a guarantee on the full engine but not on a block.
Not sure your engine has swirl flaps,but the Vito (W639) 120 CDI does, see if there's an actuator on the inlet manifold with a bar across the under side that controls the swirl flaps.
My bad mentioning it as I was in conversation on PM to someone else regarding swirl flaps in a vito.
My vito engine has a tapping sound in low revs, When above that it goes any ideas peeps?
