Tonycooper
Hi Folks,
Can any one help please? I have a vito 16 plate W447 and the LCD display in the instrument cluster has stopped working. You can see that the information is there (very very faint) but the backlight/lcd is off.
I went to an Auto Electrician who told me it was a common problem with Mercedes. He identified the part required for replacement, (doesn't supply specialist parts) and suggested I buy the part and he'll remove the cluster and replace the display. I bought the parts, the new display was fitted, didn't solve the problem.
Now turns out he hasn't got the facilities to replace the transistors (that came with the display) on the mainboard, so he really shouldn't have taken the repair on when he said he could do it, so I'm back to square 1.
Is this the kind of repair that can actually be done by an independent auto electrician (with the appropriate facilities) ? Has anyone used these cluster repair companies that you send the whole unit to and are they reliable, could you recommend one ? Or is it a visit to the main dealer with the subsequent high costs?
Thanks for your help.
