ok I had an issue with mercedes vito diesel 2012 ,the idle goes daft and cuts out at times ,so plugged van in & came up with low fuel pressure , i went ahead and replaced 3 items no1 the complete fuel rail with both sensors no2 fuel filter no3 a short fuel pipe feed to fuel filter in the centre of it gets crimped by a bracket and closes the hose , now once these had been done I then couldn't get it running again, with some help a mate told us to replace injectors this we did & got it running again ,the van runs good but I still have this issue with the idle speed, I need help people , I have connected reader and no faults in engine ,Now what I have discovered if I start the van and don't touch the rev pedal it ticks over perfect all day long but if i press the pedal and rev up the idle goes daft again ? I can then switch off van and restart without touching pedal and it will tick over perfect again , i do suspect the throttle body however its now getting to be costly and making me look stupid , I have looked around throttle body for any airleaks and used brake cleaner to see if engine picked up ,nothing happen , any advise please
