I've suddenly started having a grinding noise when braking so I assume it's time for some new pads on my van...
I've sourced the pads and had a good look at the braking system which seems to be in pretty good condition (including the discs).
Before I start I wonder if someone could give me advice about the best way to get at the pads! I see there are a couple of large bolts holding on the caliper as well as a couple of smaller bolts which seem to be longer and allow the pads to slide (centralise?)...
I assume that I remove the larger ones... Is this right? Anyone know the correct tool size for this?
Any help gratefully received...
