I read somewhere you can upgrade to a larger battery is this correct and if so what battery do i need?
Thank you
Just curious, why do you feel you need a bigger (capacity?) battery?
There is a "foot" bolted into the floor of the far end of the battery compartment.I read somewhere you can upgrade to a larger battery is this correct and if so what battery do i need?
Thank you
Once running all loads on the electrical system are met by the alternator.
