- Feb 8, 2010
- Location
- Warwickshire
- 2016 L450 Range Rover 4.4 AB, 2015 GTs 2017 Range rover evoque
Had a bit of a moment this week in the Viano, no brakes or very little.
It started with a strange dry sound and a fart like noise inside, it was like that a week then one day from parked, foot on the brake and into drive and it was off!
Pedal would pump up ok but went down very low.
Today had a good look and with the engine off and pump the pedal it would go down and then be hard and stay like that, star the engine and the pedal would drop all the way to the floor, I kept trying that and it got to the point it was just a hard pedal and no assistance, pedal would just drop.
Pulled the servo out and it has some fluid inside so I am thinking master cylinder.
The rubber boot inside above the pedal has blown off and seems dry.
Looking inside the servo seems ok, diagram is all ok but the white piston does look warn in the middle.
Before I look deeper could it be the vac pump?
It had lost some fluid but very little.
