Vito alloy fitment
Cretin211
England
Vito 114
I am hoping for some advice re wheels for my newly acquired Vito. It is a 2017 447.
I have found some wheels that I like the look of from an E class. The load rating looks good but it’s more the offset and fitment I am struggling with.
The wheels are 19x8 et43 front and 19x9 et49 rear.
Is it ok to fit a staggered setup like this on the Vito and will these offsets/sizes be suitable?
Appreciate any help
a2134012000 is the part number of the wheel in question, maybe my information is incorrect but I thought these were 750kg?
Is the bolt diameter and PCD of an E Class rim correct for a Vito? From what I can see the standard offset for a W447 is ET52.
Make sure you can get tyres of that size with a high enough load rating for the MGW. You'll need a rolling radius that matches the Vito's stock setup or the speedometer & odometer will be wrong.
Also check your insurance - quite a few companies will only cover a van with standard or factory option wheels (sometimes not even the latter!).
TBH you would probably be better off choosing something specifically designed for the W447 e.g.
The pcd is the same and plenty of images on google of them fitted to the Vito.
Does anyone know or know of staggered alloys fitted to a Vito?
That's 750kg EACH constant load.....so still a pretty useful 3000kg limit.....and failure point will be at least double that.
They need to be rated for the MGW though, which IIRC is 3050 kg for the W447 ...
