Vito battery /charging query.
jonny705
Coventry
Vito 120
Hi All, am after some advice regarding charging points on my Vito 120 2008.
Am I correct to assume that they are in engine bay ,one positive terminal in black fuse box the negative on the right and wing body?
Can I connect a charger to these points-will it be safe?
Also, if I fitted a small 12v battery across these points, could I take out main battery and would Van know if it had battery above to keep voltage in system after removal of main battery ?
I want to install a BEP marine DVS relay to feed leisure battery , so will have to take out main at some point and now car is running fine, paranoid about battery removal throwing up a fault code.
Any wisdom appreciated :)
Marku
Viano Ambiente 2.2CDI W639, S-Class 450SE W116
Replaced the battery in our Viano with no trouble. Disconnected it completely. No error codes at all. Yes the charging points are in the black fuse box on the right.
