Ok I have a Vito that, when in neutral, is grinding on a gear. The arm on the box, along with the gearstick is selected in neutral. The adjustments are correct as is the 'reverse gear selector' which is new.
It's grinding like a sod in neutral (manual box) and when the front end is jacked up and the wheels off the ground, it clearly feels like a gear is still engaged. I'm about to receive a key to drain and refill the box fluid however I'm not holding out much hope. Anyone got any ideas?
