Vito fan resistor
Simon13
London
Vito 638
My blower fan would only work on 5, so I replaced the resistor pack with a cheap chinese jobby, which latest a week. Thinking it was a bad part, I replaced the resistor pack with a much more expensive Hella part, which lasted a day. I am not keen on putting in a third replacement only to have it go again, what else should I be looking at?
Many thanks,
Simon
Hi Simon,
Not sure if this will help however this is a problem on the 639 versions, Locate and remove the pollen filter and check that the box that houses the pollen filter is not full of water.
The drain hole in the bottom gets blocked on the 639s overflowing into the blower housing.
Carl
