Darrenporter
- Oct 12, 2015
- Vito 109
Hi all, the other night I was driving my 109 2006 vito down an unlit road and went to put my full beams on, however nothing happened. I presumed the bulbs had gone (even though there was no bulb warning light) so tried the front fogs to aid my vision however again these failed to light. I returned home and today I checked the bulbs and they are fine. Whilst reinserting the bulbs I must have made a connection better as my fogs suddenly came on. However the high beams still do not light either side and when switched On the bulb warning ligh now appears. Also if the fogs are on and high beam is selected it switches the fogs off and when the full beam is unselected the fogs will come back on. I have checked fuses but there appear to be be not many fuses/ relays to check. I tested the full beam socket and got 0.3v.
I wondered if anyone has had a similar problem or knows what I should be checking next. Any ideas would be much appreciated
Thanks, darren.
Thanks, darren.
