Evening all,
First of all, I'm new here so hi
Secondly, I've recently purchased a mark 1 Vito which I'm slowly renovating. My question about the side doors is this. They don't quite sit flush to the bodywork as you look at them the top right corner (on passenger side, top left on drivers side) sticks out a little and when you close them you can see a slither of sky between the door and the seal. Obviously this causes leakage which is not good!
Is there any way they can be adjusted or is it likely to be the seals that need replacing?
Thanks in advance.
Marc
Thanks in advance.
Marc
