Vito OM651 oil temperature Sensor location P019964
ronnie63
Dundee
Vito Dualiner
Hi, I have a fault code relating to the oil temp sensor P019964 the oil temperature has a malfunction there is an implausible signal?
Anyone know the location of this sensor? Is it part of the oil level sensor on the sump?
Thanks Ronnie
It bolts into the oil pan; A0051532328; sealing ring A0002711160
LHS rear.
Brilliant thanks, my searching skills not as good as your clearly
