chopper746
Hi All,
New to the forum so if this is in the wrong section i apologise. Long story short my uncles vito had a an ecu fault which when sent too ecu testing and was unrepairable. Not wanting to scrap the van i got him a used ecu kit from ebay. Fitted this and it now runs and starts all ok been using for a couple of months now as he desperately needed it. In the kit that i brought the airbag ecu was different to the one on the van ( part number and multiplug/mountings) and i was not supplied with the abs module. Upon contacting the seller regarding trying to get the abs module he had apparently sold it. When code reading obd using a delphi scanner both abs and airbag need variant coding obviously to match cdi unit ezs etc. So basically i need to (scn) variant code both abs and airbag i would like to also code the other keys we have so we have a spare and if possible adjust mileage. his vans done 107k and the instrument cluster fitted has 155k. I have a geniune mercedes star scanner at my work but i do not have online xentry nor offline access for scn coding as the company i work for doesnt really need it. So my question is can any body point me in the right direction to move forward, i.e someone who can match the control units or a way to obtain offline xentry access ? Any advise would be appreciated.
Many Thanks,
Ross
Many Thanks,
Ross
