Just fitted new tailgate struts to my Vito. Not as easy as I thought it would be ! Easy enough to get the old ones off, they were shot. I supported the tailgate with a length of wood and did one at a time. The new ones needed to be compressed a little to get them to fit without a struggle. Unfortunately I couldn't think how to do this, so I fitted it to the tailgate first, removed the bracket with the ball attached and put a piece of masking tape where the bracket had been and added a little grease to it. Next I attached the free end of the new strut to the ball, pushed it up to the body as far as it would go and proceeded to lever it up to the required position with a screwdriver inserted in one of the bolt holes. Next I entered the lower bolt in the hole and screwed it in, keeping the bracket in line for the upper bolt. The upper bolt was more difficult, as the strut is now in the way of getting straight on the bolt so I managed to get it tightened most of the way, using an allen key like tool to finally tighten up. Repeat other side and job done !
Was a bit fiddly, but not bad.
Now I suspect that many of you have carried out this job on your own van but doing it another way, want to share your experience ? Cliff.
