Vitovan888
Hello I’m new to this forum and need help please.
I have a Vito van 2007 that was running good until a few days ago....went to van and key turned in ignition lights came on on cluster but at the end of the turn nothing from the engine
Call me brother and he said rock the van in gear as starter motor may be stuck
I rocked the van in gear... all lights went out on cluster and it started turning over with cluster lights off, I took the key out and van was still turning over then about 10 seconds the battery ran flat
I have tried jump starting the van but it just turns over the starter motor as soon as I put the leads on and this is with no lights on dash or key in ignition.
Had the Ignition key and ignition checked and the ESL is not on
The Van is dead I can not open doors with fob or radio does not work nothing electrical at all works
I can not get any codes as the ignition has no power
Any ideas ?
Any ideas ?
