GTRremap
Hello,
Needing some wiring help, i am a mechanic and i have changed all the sensors and brakes on this vito and still getting the brake pad warning with the SAMS fault for break in the wire but as the wires run through the van i am desperate to get the wiring from the SAMS unit to turn this off, why this cannot be programmed out escapes me, the Dualiner is kitted out and i do not want to strip the van to fix a wire that really isn’t needed!
I know potentially it could be the SAMS unit but if i bridge at source i’ll know if its a break or the unit and i need this fixed as its a MOT requirement even although it has brand new brakes, i just cannot find what wires and pin data for this nor even a fuse?
Thank you.
Scott
GTR REMAP LTD.
Thank you.
Scott
GTR REMAP LTD.
