PhilTheVan
- Nov 14, 2021
- Location
- East Cowes, Isle of Wight
- 2010 Mercedes Benz Vito W639, 111CDi Compact
Hello all, I hope you're well?
I have just treated myself to a 2010 Vito 111CDi Compact which I'm greatly enjoying. Among a few little niggles is the heater control. I can't adjust either the temperature nor where the air is being blown (windscreen, feet, face etc). After taking the front panel off I found that neither dial is connected to the control. The control arm (I don't know that actual name which is part of the issue) for the temperature dial wasn't plugged in, it was just hanging loose so I've plugged that in and can now adjust the temperature with no issues. Trouble is the control arm for the other dial is missing completely so there's no way to adjust where the air goes and I don't know the name of the part or the part number, or even if I can get one of these little bits? I found the image below which has the parts labelled as A and B :-
Can anyone please help? The part numbers or even names would be great - I can find the whole heater control on eBay but don't need the whole thing.
Thanks in advance,
Phil.
Thanks in advance,
Phil.
