DeaneLyons
hi all, I’ll try and keep this short. Had an issue with sticking ignition a couple of months ago so used a liberal amount of WD40 around the barrel and gave it a load of movement. Things improved slightly so decided to leave it to soak (still in the the van). Not used it for a few weeks and went to try it but now the is no life in the barrel now. So when you put the key in there is no click and you can’t turn the key. Now, after some messing I got the module out to see if there was any WD40 where it shouldn’t be but all was clear. After a bit more messing I heard a piece drop off and luckily found it. It looks like a copper contact of sorts. My thought is that is this is what was failing and starting to jam the barrel and in my vigour trying to get the WD around it finally snapped. It looks like a contact so I’m guessing it it not allowing the coil to energise and subsequently not energising the key so it’s not recognised.
I hope this is sort of clear and was wondering if anyone else had expected this problem. And if anyone has any photos of an intact unit so I can see where it came from.
Many thanks in advance and stay safe.
Deane
