E240estate
- Aug 19, 2014
- 2003 S211 E240 Estate; 2003 W638 Vito
I replaced the head gasket on this engine, and have had a nightmare trying to get it restarted after rebuild. The injectors were stuck so i had to remove them with a screw type puller, which meant I had to disassemble the injectors in situ and then reassemble them before sticking them back. I did almost 1,000 miles in this van before I did the work and it ran faultlessly.
I have used up two full charges of a good battery cranking it over and over, and bled out as much air as possible form the fuel lines around the fuel filter.
As a last resort this morning I tried easy start, which got the engine running on 3 occasions, for up to a minute. It would tend to keep running with the accelerator down, but would not idle or keep running indefinitely, and failed to start again without another squirt of easy start to get it going.
There are no fault codes stored in the ECU and no EDC or any other lights have come on.
Can anyone offer any pearls of wisdom as to how I might get the van up and running properly? I've obviously put it all back together correctly for it to run, and there is half a tank of diesel in it. Otherwise I'll have to assume I have somehow damaged the injectors, which is going to cost £££, so I don't want to go down that road until I've eliminated everything else.
W638 108CDI OM611 engine.
Thanks in advance
Thanks in advance
