eammon
Hi every one. That is my first message in your wonderful forum. I have found the forum informative nd indispensible for a mercedes benz owner. My car had the usual issues like CAT rattle and airmatic pump failure which I was able to rectify with the help of your forum. However yesterday I had a warning sign regarding a low beam R check bulb as well as side bulb R check Bulb. I replaced the side one as it was visibly burned, However the low beam one was not visually showing any burn damage. However i replaced it too. Now the side bulb working but not the low beam one. Every other bulb in that side and L side working. No fuses to check as it indicates in the fuse chart ELECTRONIC FUSE. The wiring seems to be in very good condition at the bulb point as well as the main connector behind the headlight connector. Any ideas what can be the fault ?? Thank you.
