W!@$ Battery Dead, Can't open Boot?Trunk.... EMERGENCY!!!
Prof.C.Benz
London
1991 W124 300CE (M103)
W124, Battery is flat, don't have a jump, need something that is in the boot...
None of the keys will open the boot lock...
Any Ideas??
Lubricate the boot lock and keep trying.
No, it doesn't want to turn at all.. not even a little bit.. If I try and force will snap key.. May have been replaced and key not supplied...
If it is an emergency then use an angle grinder or some other tool to cut through the metal skin..
You might get through via the first aid box in the parcel shelf, alternatively sacrifice a tail lamp or the boot lock to gain access.
