roocarl
please advise where ever i put heater controls I have hot air streaming into cabin?
With engine running check operating dash levers actually makes white lever on valve work. If not then possible vacuum pipe off at dash. Facelift 107s have vacuum pump in boot to work door locks. The rest, heater valve, headlamp adjust only need to work when engine running so not sure if vacuum system actually has storage tank. Not sure of this point however.
Does the headlamp height adjust work, if not indicates possible vacuum pipe off at manifold.
Hi levers on dash have no effect on vacuum levers if engine on or off ,I checked headlight adjustment nothing happens and checked vacuum pipes still attached to levers on back of dash but there seems no pressure ,
I tied vacuum lever down to stop hot air which worked in stopping hot air ,
Then It snowed I was getting too cold and window would not demist !
So apart from attaching a piece of string to vacuum lever and routing through window im struggling to find a solution ??????????
Carl
