Hello,
I have a w123 (240td) 1982 - only 120kms though. Ever since taking it to have th injection pump adjusted a few years ago, I have leak of oil between the pump and the engine. I tried tightening a bit but it doesn't help.
Is there a gasket between these two parts? I looked at some diagrams and it seems not.
If so (and even if not!) how easy is it to remove the pump to replace it or move it out a bit so I can put sealing compound in there? Is this the solution anyway?
thanks
stuart
thanks
stuart
