w123 engine conversion
Anything you like can fit in there, depends on how much you want to spend. Past conversions are normally the m117 v8 from the s class, but I'm sure there are others.
Did you have anything in mind?
I actually like the 230E engine... its a good balance for the W123 and with 5 speed manual its perfect..
However if you want to go mad the M117 560 is the way forward but there are several modifications required - by no means plug and play.
+1 for the 230E engine or seeing that your car is a 200D, perhaps a powerful engine from a 300D or even TD
was thinking of a compressor but im open to anything obtaining a full car would be favouerd but still needs to be fairly cheep i dont think i;ll get a v8 cheep
If you're still thinking of a diesel you need to go on here and search 'Projects' to see what is possible.
STD
Hi,welcome to the forum:thumb:
thanks for everyones intrest will keep looking and keep everyone posted
