W123 Headlamp Washer & Wiper Electrics
paddingtonfire
London / East Anglia
1992 W124 300TD Estate & 1982 W123 280TE
Evening All,
Hoping someone can help. I've recently been spending a bit of time sorting out the headlamp washer and wiper system on my 280TE. If I deal with the lamps first, the drivers side wiper worked, the passenger didn't, so I sourced a replacement motor, in fact two that had been tested, and they both didn't work on the passenger side. On the washers, the windscreen works fine, but the headlamp washer motor, that I've replaced and tested, yet it's still not working.
I was wondering if there could be a wiring issue from the relay. The said relay appears to click in and out ok (or if anyone knows if the internals of that could be a reason, but I can't see that somehow), I'm a bit stumped.
If anyone can help I'd appreciate it, or do I look for an auto electrician??
Cheers,
Mike
