I have replaced one side of the rear subframe front mount. No problem. I removed the other side, removed the mount, replaced it only to find that the subframe seems to have moved relative to the body so the bolt goes through the mount but will not engage in the chassis.
I have tried crowbars, jacks, wedges - you name it - to realign things. I have tried jacking the vehicle up and then jacking the subframe up and vice versa. It simply will not bite the thread. The threads are OK since it screws in with the mount removed.
I am tempted to give it some Barnsley screwdriver treatment but guess this will knacker the thread.
Anyone had the same problem and know the fix? Since the bolt is tapered, is it designed to be hammered in? Should the body be jacked up and the subframe jacked up or does it not matter?
Needless the say, the car is totally undriveable with a loose subframe.
Any ideas or advise welcomed! I am at my wits end...
