NormanB
W124 (1989) Engine Cooling Fan - Electromagnetic Fan Clutch.
Hi
I had a bank holiday motoring experience today and I feel a 'reet chump'!
Basically spent an hour in start stop conditions and engine temp rose...and rose until (I suspect) the expansion chamber pressure cap lifted and let go of the coolant - it was quite impressive. Fortunately I managed to slide over into a vacant parking slot within 10 metres!
Opened the bonnet and satisfied that it was not on fire (had a 'FUD' moment (fear uncertaininty and doubt)) and that there was only oil in the sump, fed the meter and took my daughter to the planned trip to the cinema to see Harry Potter, which fortunately was only a ten minute walk.
On return, the engine was nice and cool, rechecked the sump and relieved to find only oil and at a normal level. Topped system up with oggin and ran engine which soon reached normal operating temperature and thermostat opened at spec. No leaks found.
My guess is that the electromagnetic fan failed to cut in. What are my options where is the sensor - how can I test the unit electrically and is there a strip out option on the fan clutch or is it upkeep by exchange.
Grateful for any techie advice, wise words or guidance.
NormanB
PS: I fell asleep within the first 10 minutes of Harry Potter, my ten year old daughter is well trained and left me alone until I started snoring!!
She tells me it was a really good film!!
Hi
NormanB
