GDSP
Hi guys, need your help please, my merc w124 2.5 diesel multivalv doesn't starts on its own battery, battery is fine, i put another one just for testing and it won't start. Strangely if I use a booster to jump start it it starts in a snap ! But then it runs rough, low power high smoke and tries to stall, engine noises... If I turn it off it won't start again until I use the booster to start it! I noticed also that sometimes the dash light of the glow plugs doesn't turn on, but if it does it won't start all the same... I tested the glow plug relay and I have voltage on all 5 connectors. I'm really lost here, I also have an Toyota Avensis Diesel that had the same symptoms and after replacing the relay it resolved the problem, but the relay was dead Wich is not the case with the merc! Thank you all!
