Hi Guys,
This is my first post in the forum.
I have recently acquired a 1993 W124 220E. I got it from my father in law, it needs some work which I am starting to get to.
There is a problem with the transmission, it pulls off perfectly but then proceeds to shift directly into 4th gear and will not shift back down or kick-down. I am under the impression that this gearbox is controlled by vacuum pipes? Am I correct in assuming this? Where would I be able to find these pipes? I have been searching the forums without too much luck. I have found some reference to vacuum pipes but these refer to the central locking system.
The thing is, this gearbox was recently pulled out and serviced by some back-yard mechanics. I'm not sure what they did exactly. The box seems to go fine, just changes too quickly, resulting in the vehicle not having any power unless you floor it to get it up to speed quickly before it changes into 4th.
Any ideas guys?
PS: I hope I have posted in the correct forum and asked for help correctly.
O
Any ideas guys?
O
