Hi!
Car was squealing and thought it was the belt.
Loosened the belt via the lower mount on the the Alternator but now the alternator wont fit into the lower mounting. It will fit once the belt is off.
I then opened the tension bolt to see could I loosen the belt, but it make no difference, The belt remains tight.
(From Google searches, one should only move it half a turn but eventually I did several turns with no effect)
I unscrewed the tension adjuster but the pointer remains in the middle if the triangle.
Any ideas from a stressed W124 owner?
Cheers
Cheers
