W124 300 12v Starting Problems
DanMorgan
Cardiff
R129 300SL 24V, W124 300CE, W210 E55 AMG, W140 S280
Wondering if you could give possible solutions for a problem I have
The car won't start but it has a good ignition spark, I can hear the fuel pump working and have pressurised fuel either side of the fuel distributor (inlet and return) however no fuel to the injector when cranking over the engine.
Does this mean a faulty fuel distributor?
Regards,
Dan
grober
MB Master
Perth, Scotland
W204 C200CDI Estate
FAULTY FUEL PUMP RELAY---- its 2 stage- Initial pressurising stage then requires an "engine running" signal to maintain power to the pump-- it may also supply a feed to the extra starting injector.
OP
OP
D
DanMorgan
Cardiff
Will purchase one ASAP and report back with the outcome. You may have saved me a few quid as I was going to purchase a second hand fuel distributor! :thumb:
grober
MB Master
Perth, Scotland
W204 C200CDI Estate
Lots of posts about this on the forum if you do a search . The engine running signal is a safety feature to stop the fuel pump running in the event of a crash/engine stop situation where fuel would continue to be pumped into th engine compartment. As a test the main relay contacts can be bridged temporarily to keep the fuel pump running continuously. If the car then runs you can be pretty sure its the FPR.
OP
OP
D
DanMorgan
Cardiff
I forgot to mention that when I first put the ignition on - I can hear the fuel pump 'buzz' for approximately 5 seconds. Does this mean the relay is okay?
grober
MB Master
Perth, Scotland
W204 C200CDI Estate
No it means the first "pressuring stage" is working the second stage may not. This could be the relay or its not getting the engine running signal.
BlackC55
Portsmouth, Hampshire.
E55K SL500 E300Hybrid E250X3 Viano C55 E450Cab A180 Smart 44 Brabus
Bridge the relay to confirm. Terminals 30 and 87
OP
OP
D
DanMorgan
Cardiff
Bridged the relay, however still no fuel coming from the connector the injector thus no engine start.
Any more suggestions?
Thanks,
Dan
GP801
Sussex and Tuscany
2003 W209 CLK, 2005 R171 SLK in UK, 1995 S124 E280 in Italy
Our 280 had a similar issue with the fuel pump running intermittently. It needed both the fuel pump and OVP relays replacing to solve the issue. A dodgy OVP really seems to affect all sorts of things. Realise not the same engine but might be worth considering
OP
OP
D
DanMorgan
Cardiff
Thanks for all the input. Today the issue was fixed - I bought a second hand working fuel distributor and its now fires up. I had to run the car for a while to clear up all the gasses in the engine, but it idles perfect and sound good. Just need to get a new OVP to improve the startup!
