Druk
Gone but not forgotten - RIP
- May 28, 2004
- Location
- Not far from Edinburgh.
- 2011 S212 E350CDi. 1981 R107 300TurboDiesel.
The Haynes manual 3253 referring to the vacuum stop element on the injection pump says...
"When the ignition key is turned 'OFF' the switch interrupts the supply of vacuum to the shut-off module stopping the engine"
This surely is incorrect? Me sucking on the vacuum module causes the manual stop lever to move across presumably to the 'stop' position. Does the ignition switch -when its switched off- not put vacuum to the element causing the engine to stop?
I'm trying to arrange a remote (not vacuum) STOP mechanism and am confused. Engine not as yet in a running state to be able to try it out.
