W124 300D rear crank seal leaking?
Discussion in 'Engine' started by gregdeklerk, Jan 15, 2009.
  1. gregdeklerk
    gregdeklerk New Member
    2
    Jan 13, 2009
    Cape Town, South Africa
    Car:
    1987 W124 300D, 1991 W124 200E, 1996 W124 E250D
    I have a 1987 300D which is auto and has the OM603 engine. The rear crank seal is starting to go as I have noticed a few drops of oil on the garage floor and it is engine oil coming from between the engine and gearbox. How long should I leave this as there is not a lot of oil, but it can only get worse! Since it is auto, there is no danger of oil on the clutch plates.
    Thanks.
Share This Page
