bigjim
- May 17, 2010
Hi there
A few weeks ago the 'coil' light didn't come on until after the car had started. Then a few days later the car wouldn't start. I guessed the glow plugs. I did the usual glow plug checks and replaced a faulty one (all GP showed under 1ohm of resistence while the faulty one had about 50ohms!.
Unfortunately the car still doesn't start. There does appear to be air bubbles in the outlet from the main filter but I can't seem to get rid of them. I've tried bleeding from the injectors and wondered if there is anything else I should try?
Thanks in advance
Jim
Thanks in advance
Jim
