TVRTASMIN
- Nov 3, 2006
- Location
- Steeton
- W124 300TD. W124 E300D. Rover P4 110. Rover P6 3.9. Various TVR's Two Ducati's.
I am selling my trusty estate as i don't need the room anymore.
Pictures here;
http://www.pistonheads.com/sales/418223.htm
It has full MB main dealer history and most recently independent specialists.
Servicing has been carried out usually every six months or 3,000 miles.
The most recent included the fuel filter and poly 'V' belt.
I have owned the car for about 18 months in which time it has had two new front wings fitted. New front springs and gas dampers plus top bearing bushes. New wishbones and rubber bushes.
The ARB bushes have also been replaced.
All the brake hoses and lines have been replaced plus new discs and pads were fitted last year.
Overall condition is excellent as would be expected of the W124 .
Mileage is currently 289,000 but starts first time hot or cold and does not smoke.
Recently i had a custom 11 gallon aluminium tank made to fit below where the 7th seat would normally go, and the trap door hides the top of the tank and Mocal filler. This is for use with vegetable oil, new or waste.
The two fuel lines have been run into the engine bay to connect to the water heated heat exchanger, glow plug type heat exchanger and a heated fuel filter via a 12v solenoid valve. There is also a dash mounted temp guage with the kit.
All the rubber fuel lines have been replaced with Viton type and the fuel tank filter has been replaced.
The MB spec for the car is as follows;
VIN WDB1241902F143794 Model 300 TD Chassis 1241902F143794 Engine 603912 22 038248 Transmission 722415 02 901265 Order 0 0 537 82132 Approx. year 1990 Lights BOSCH Wiper BOSCH Cab 00028 Dealer Great Britain (537) Interior mb-tex mushroom (175) Paint 261 willow green metallic (1986-1991, с 1994) Options 341 additional lamp (с 01.09.1982)
362
412 electric sliding roof with tilting device (с 01.07.1983)
420 automatic transmission, floor shift (с 01.01.1963)
440 tempomat (cruise control) (с 01.09.1975)
461 Unknown code 524 paintcoat preservation (с 01.01.1964)
541 double roller blind used as luggage and passenger guard (с 01.01.1980)
570 folding armrest front w202/210 stowage box front with armrest (с 01.04.1970)
front folding armrest w202 - housing at front with armrest
584 electric window lifters (front and rear doors) (с 01.04.1970)
electric window lifters, fourfold or sixfold
593 heat-insulating glass, all-around, heated rear window pane (single-sheet safety glass), band filter
green heat-insulating glass all round, heated rear window, single pane safety glass - tinted strip (с 01.01.1972)
613 lamp unit, asymmetrical, l.h. traffic (с 01.02.1963)
722 baggage rack, integrated (с 01.07.1981)
724 cargo anchorage (с 01.04.1979)
The load cover and net are included.As is the original Blaupunkt Casablanca stereo.
I'm looking for £1,450 and this includes 6 months tax and 6 months test.
Drivers handbook and wallet are all present including extensive service history etc plus past mot's.
Pictures here;
362
